I am trying to create a power supply with both positive and negative voltages. Is it possible to use this transformer to create such a supply? : https://my.element14.com/vigortronix/vtx-146-050-215/50va-toroidal-transformer-2x15v/dp/2817652
Basically, want to use the center tap of a transfomer's secondary winding to create both negative and positive voltages with common ground. But I am not sure if the mentioned transformer's double secondary winding can be used to do such a thing. Is it two separate secondary windings without any connections in between? What if I connect two wires from each secondary winding together and use that as the GND ground? Will that method work? Or the voltages will be out of phase? Please need some help regarding this. Thank You.
