This is the schematic for a fuzz circuit. Even knowing that the diode is probably what's providing the signal clipping, I still can't figure out how I'm supposed to analyze the circuit.
When V(collector - base) < 0.7volts, the diode acts as an open circuit, and there's no feedback path, and as long as the base voltage is forward-biased, the transistor acts like an amplifier (linear region).
When V(collector - base) > 0.7volts, the diode is... shorting the base and the collector?
