I'm tried to find the solution, but I failed.
my question in the figure below, and the correct answer it's shown at the end of Figure.
I'm using this formula but the answer is not correct! enter image description here
Is there another solution to this question?
  • \$\begingroup\$ What is \$\Delta f\$ equal to in this example? \$\endgroup\$
    – AJN
    Jun 19 at 9:43
  • \$\begingroup\$ Δf =RS/2 ==> Δf =250 \$\endgroup\$ Jun 19 at 10:04
I think there's not much right here in the question, the slides, and your answer, so that's not your fault. The author confuses "\$M\$-tone Frequency Shift Keying" (M-FSK) with "Minimum Frequency Shift Keying" (MSK). These are two different things.
In all literature I could find¹, MSK is defined as a 2-FSK with a \$\Delta f= \frac{R_s}{2}\$ spacing. However, the slides apply the properties only achievable through that to FSKs with more than two frequencies.
That doesn't work that way; the orthogonality can't be maintained at this spacing for \$M>2\$, nor is the bandwidth formula generally correct even for the \$M=2\$ case (see: the difference between "pure" minimum shift keying (MSK) and Gaussian minimum shift keying (GMSK).
So, as sad as that is, your question "what's wrong about my answer and right about the test's answer" is impossible to answer correctly, because the premises of that test are wrong. :(
¹ that would be
  • Proakis' Digital Communications, third edition, p-196
  • Bernard Sklar's Digital Communications and Applications, second edition, p. 559,
  • M. Simon, "A Generalization of Minimum-Shift-Keying (MSK)-Type Signaling Based Upon Input Data Symbol Pulse Shaping," in IEEE Transactions on Communications, vol. 24, no. 8, pp. 845-856, August 1976, doi: 10.1109/TCOM.1976.1093380. ,
  • J. A. Schoonees and R. M. Braun, "A note on the orthogonality of MSK signals," 1993 IEEE South African Symposium on Communications and Signal Processing, 1993, pp. 123-127, doi: 10.1109/COMSIG.1993.365860. ,
  • Wikipedia, and
  • the patent that defined the term "Minimum-Shift Keying (MSK)" 1961: US2977417
