Accidently i gave my pi high voltage (10V 1.8 amps) after that there is no video output. Im connecting my pi to monitor(not tv monitor) and the monitor says there is no video output. I've tried with new sd card and change config.txt it havent worked. I need full circuit datasheet for raspberry pi4 model B for check the all routes. Im new in this do you guys know another solution other than software problems cuz i think my problem is not software problem
  • 7
    \$\begingroup\$ do you guys know another solution - Buy a new one. \$\endgroup\$
    Jun 20 at 10:54
    \$\begingroup\$ Do you see a led (the green ?) blinking at boot ? If not ... sorry ... \$\endgroup\$
    – user288518
    Jun 20 at 12:05
    \$\begingroup\$ You have released the magic smoke. It is a 5V device and you have applied 10V, you know the answer, now you have to accept it. \$\endgroup\$ Jun 20 at 14:00
  • \$\begingroup\$ how would a full schematic help you? \$\endgroup\$
    – jsotola
    Jun 20 at 18:57
  • \$\begingroup\$ When i put in the sd card green light is on, when i pull the sd card green light blinking 4 times \$\endgroup\$ Jun 21 at 13:05
It is highly probable that your RPi is irretrievably destroyed. Delicate semiconductors (MCUs, SOCs etc.) are very sensitive to voltage spikes (Even spikes as small as a few hundred millivolts can destroy those chips, let alone double the rated input voltage.)
Also you will probably not find the full schematic of RPi, because it is not public.
