I am currently working on an Arduino to NIOS II Compiler that I am using on GitHub. I have provided a link to the compiler here: https://github.com/dimag0g/nios_duino. The issue I am having is that I am unable to compile my top level file because of two errors, one of them regarding syntax and the other regarding module declaration.
Below is my code for my top level module:
  *FPGA Interconnect Module for the NVSRAM Database, SRAM PUF, & UI
  *SRAM PUF connected through GPIO pins to parallel IO
  *NVSRAM database connected through GPIO pins to I2C module
  *User Interface connect through UART/USB to NIOS
  module sawblade_project (
     input wire CLOCK_50_B5B,           // Clock signal
     input wire [35:0] GPIO,            // I/O pins for
     input wire LEDR0,                  // Connect to PIO 13 to verify the code is working
     output wire UART_TX,               // UART ports for UI computer
     input wire UART_RX                 // Uart ports for UI computer
//tie SRAM_VCC_CNTRL high, BLE low & BHE high
     always begin
                 GPIO[32] = 1;              //SRAM_VCC_Control tied high
                 GPIO[33] = 0;              //BLE tied low (active low)
                 GPIO[35] = 1;              //BHE tied high (active low)
     end
//instantiate nios_duino module
     nios_duino u0 (
                .clk_0_ext_clk(CLOCK_50_B5B),               //Clock signal @ 50 MHz
                .clk_in_reset_reset_n(KEY1),                //Clock reset signal
                .cpu_reset_cpu_resetrequest(KEY0),          //CPU Reset request signal
                .cpu_reset_cpu_resettaken(LEDR1),           //CPU Reset taken signal
                .i2c_0_ext_sda_in(GPIO[20]),                //SDA for NVSRAM database
                .i2c_0_ext_scl_in(GPIO[19]),                //SCL for NVSRAM database
                .i2c_0_ext_sda_oe(1),                       //I2C data buffer tied high
                .i2c_0_ext_scl_oe(1),                       //I2C clock buffer tied high
                .pio_0_ext_export[12:0](GPIO[12:0]),        //GPIO to PIO IP
                .pio_0_ext_export[13](LEDR0),               //LED signal @ PIO 13 to ensure compiler operation
                .pio_0_ext_export[19:14](GPIO[18:13]),      //GPIO to PIO IP
                .pio_0_ext_export[30:20](GPIO[31:21]),      //GPIO to PIO IP
                .pio_0_ext_export[31](GPIO[34]),            //GPIO to PIO IP
                .uart_0_ext_rxd(UART_RX),                   //UART receiving line for UI interface
                .uart_0_ext_txd(UART_TX)                    //UART transmission line for UI interface
endmodule
This time, I made sure not to compile either the template files that came with my project once I generated the code using the Platform Designer (SOPC Builder). Nevertheless, I am still receiving this error from the compiler:
 Error (10170): Verilog HDL syntax error at sawblade_project.v(31) near text: "[";  expecting
 ")". Check for and fix any syntax errors that appear immediately before or at the specified
 keyword.
Could this error be because I am not instantiating the pio_0_ext_export bus correctly, or is there another issue entirely?
In addition I am also having a module declaration error with one of the submodules:
 Error (10228): Verilog HDL error at nios_duino_sysid_qsys_0.v(34): module
 "nios_duino_sysid_qsys_0" cannot be declared more than once
However, I have checked the code for this submodule and that does not appear to be the case, especially since this submodule code was generated by the Platform Designer and was not edited by me. Here is the code for the nios_duino_sysid_qsys_0 module for reference:
 // (C) 2001-2018 Intel Corporation. All rights reserved.
 // Your use of Intel Corporation's design tools, logic functions and other
 // software and tools, and its AMPP partner logic functions, and any output
 // files from any of the foregoing (including device programming or simulation
 // files), and any associated documentation or information are expressly subject
 // to the terms and conditions of the Intel Program License Subscription
 // Agreement, Intel FPGA IP License Agreement, or other applicable
 // license agreement, including, without limitation, that your use is for the
 // sole purpose of programming logic devices manufactured by Intel and sold by
 // Intel or its authorized distributors.  Please refer to the applicable
 // agreement for further details.
 //Legal Notice: (C)2010 Altera Corporation. All rights reserved.  Your
 //use of Altera Corporation's design tools, logic functions and other
 //software and tools, and its AMPP partner logic functions, and any
 //output files any of the foregoing (including device programming or
 //simulation files), and any associated documentation or information are
 //expressly subject to the terms and conditions of the Altera Program
 //License Subscription Agreement or other applicable license agreement,
 //including, without limitation, that your use is for the sole purpose
 //of programming logic devices manufactured by Altera and sold by Altera
 //or its authorized distributors.  Please refer to the applicable
 //agreement for further details.
 // synthesis translate_off
 `timescale 1ns / 1ps
 // synthesis translate_on
 // turn off superfluous verilog processor warnings
 // altera message_level Level1
 // altera message_off 10034 10035 10036 10037 10230 10240 10030
 module nios_duino_sysid_qsys_0 (
                // inputs:
                 address,
                 clock,
                 reset_n,
                // outputs:
                 readdata
   output  [ 31: 0] readdata;
   input            address;
   input            clock;
   input            reset_n;
   wire    [ 31: 0] readdata;
   //control_slave, which is an e_avalon_slave
   assign readdata = address ? 1623863076 : 17149200;
 endmodule
  • \$\begingroup\$ First of all, you can't assign values to an input like " GPIO[32] = 1; " \$\endgroup\$
    – David
    Commented Jun 21, 2021 at 19:44
  • \$\begingroup\$ Weird coding. Why are you forcing the inputs of a module? You should write a wrapper and force inputs of the module there and take out only the needed inputs to the IO interface of the wrapper. \$\endgroup\$
    – Mitu Raj
    Commented Jun 21, 2021 at 20:07
  • \$\begingroup\$ The reason I had forced these inputs is because I only need them tied high or low. How can I go about creating a wrapper to do this? \$\endgroup\$
    – Conlin6241
    Commented Jun 21, 2021 at 20:13
  • \$\begingroup\$ Or could I simply change the specification for my GPIO pins to inout instead of input? \$\endgroup\$
    – Conlin6241
    Commented Jun 21, 2021 at 20:16
  • \$\begingroup\$ Try: .pio_0_ext_export({GPIO[34], GPIO[31:21], GPIO[18:13], LEDR0, GPIO[12:0]}) \$\endgroup\$ Commented Jun 21, 2021 at 21:19
There are a couple of issues here, one is with the assignment to an input, and the other is trying to index part of a port with .portName[bitRange](connection) being invalid syntax.
In terms of the second case, if you want to assign multiple different signals to a single multi-bit port, you should instead use concatenation:
However this doesn't get around the first issue of trying to assign some GPIO pins to be inputs. Looking at your code, it seems you want those hard-wired pins to actually be outputs. If this is the case, you can simply change that line to:
inout [35:0] GPIO,
This will make the port bidirectional - pins can be inputs or outputs. Then your assignment will be possible. However not quite as written. Your port is still a wire type, so assignment in a procedural block is not possible. Instead, replace the always block with:
assign GPIO[32] = 1;              //SRAM_VCC_Control tied high
assign GPIO[33] = 0;              //BLE tied low (active low)
assign GPIO[35] = 1;              //BHE tied high (active low)
The latter error message about multiple module definitions sounds like you have multiple files declaring the same module.
Have you by any chance included a file called nios_duino_sysid_qsys_0_bb.v or other duplicate files in your project?
  • \$\begingroup\$ Thank you for your help with the syntax error! As for the second error, I have gone through my project and its files. In my project I have the .qsys file I generated the Verilog code with, the generated module nios_duino.v, the top module sawblade_project.v, and the .qip & .sip files. The .qip file contains one copy of all of the submodules, including nios_duino_sysid_qsys_0. Just in case, I checked through all of the folders that my project generated and could not find a duplicate or black box file. Is there anything else that could be the culprit? \$\endgroup\$
    – Conlin6241
    Commented Jun 21, 2021 at 22:16
  • \$\begingroup\$ Declaring a signal as inout just for the purpose of reading is unnecessary headache during place and route and IO constraining. And such a port will not be easy to integrate with other modules. So I would suggest keeping GPIO as outputs itself as OP want, and then use an internal signal for GPIO instead, for the purpose of reading inside and assigning to GPIO. \$\endgroup\$
    – Mitu Raj
    Commented Jun 21, 2021 at 22:37
  • \$\begingroup\$ Update: There was a duplicate nios_duino.v file in the qip folder. However, I am still receiving the declaration error. Could there be any other causes? \$\endgroup\$
    – Conlin6241
    Commented Jun 22, 2021 at 0:21
