Enter image description here
I have this waveform and I would like to have the Y.
I know that the equation is Y = D' + E' + F'.
Where it has ' it means NOT.
As I see it, the only thing I did, and I am not sure if it is right, was this:
If I got it right, this is it:
    \$\begingroup\$ At the very beginning, D' is True, so Y should also be True. \$\endgroup\$
    – ErikR
    Jun 22, 2021 at 0:20
  • \$\begingroup\$ you mean I am right @ErikR ? \$\endgroup\$
    – ek.Nik
    Jun 22, 2021 at 0:21
  • \$\begingroup\$ You've drawn Y as being False at the beginning and only True near the end (where the bump is) \$\endgroup\$
    – ErikR
    Jun 22, 2021 at 0:22
    \$\begingroup\$ I've updated my answer. \$\endgroup\$
    – ErikR
    Jun 22, 2021 at 0:55
    \$\begingroup\$ @Yun.kon - your last graph is correct. \$\endgroup\$
    – ErikR
    Jun 22, 2021 at 1:28
6 Answers 6
7
Do the analysis graphically.
Any red section in D, E or F will cause Y to be true.
You will also see that D is not required to generate Y.
    \$\begingroup\$ D is not required to generate Y WITH this example. \$\endgroup\$ Jun 22, 2021 at 16:39
The exercise shows the application of DeMorgan's Theorem. Stated simply,
  • A'+ B' is equivalent to (AB)' (negative-in OR into positive-in NAND)
Likewise,
  • A'B' is equivalent to (A+B)' (negative-in AND into positive-in NOR)
In this case, you have three inputs. Doesn't matter, DeMorgan's Theorem extends to any number of inputs:
  • Y = D'+E'+F'
converts to..
  • Y = (DEF)'
that is, the NAND of the three inputs.
Y will be low when all three inputs are high. Based on the sequence, Y will pulse low only at the end, when DEF are all high.
More about DeMorgan's Theorem here: https://www.electronics-tutorials.ws/boolean/demorgan.html
Do a truth table for both (D' + E' + F') and (DEF)'. They will be the same.
The other answers are already good, but since you have all inputs negated, then it might help you to simply flip the picture up-side down:
flip
All that's left is to see where all of the three traces are false.
Since Y is equal to the sum of (not D), (not E) and (not F), it will be true whenever any one of D, E and F is not true. For then at least one of the three terms will be true. Thus, in your diagram, Y will be true or high whenever any of D, E and F is not true or low. It will only be not true or low whenever all of D, E and F are true or high. You should be able to construct Y from this information.
The easiest way to read the boolean equation Y=D'+E'+F' is D is false OR E is false OR F is false.
If you understand how to translate from your boolean to my English equivalent, the correct answer should be obvious. If any of D, E, or F are false, the output will be true. So it's always high, except when all three inputs are true.
Times 1, 2 and 3 are indicated by the green lines.
At time 1, D, E and F are all False.
At time 2, D and E are False and F is True.
At time 3, D is False, E is True and F is False.
    \$\begingroup\$ This is incorrect. \$\endgroup\$ Jun 22, 2021 at 0:47
    \$\begingroup\$ why it is incorrect \$\endgroup\$
    – ek.Nik
    Jun 22, 2021 at 0:48
    \$\begingroup\$ Missed the inversion for (D'+E'+F') = (DEF)'. \$\endgroup\$ Jun 22, 2021 at 0:48
    \$\begingroup\$ @hacktasical - Y is from the OP's answer. I was just explaining how the logic levels are determined for D, E, and F. \$\endgroup\$
    – ErikR
    Jun 22, 2021 at 0:51
    \$\begingroup\$ You still don't show the correct logic or waveform. \$\endgroup\$ Jun 22, 2021 at 1:02
