I've been trying to find a way to set custom timings for signals coming from a digital vector file in a simple test circuit with 4 inputs and 4 outputs as shown.
I used 4 of these to easily observe input/output behavior.
My digital vector file code is :
radix 1111
vname v<4> v<3> v<2> v<1>
io iiii
tunit ns
period 10
trise 0.01
tfall 0.01
vih 1
vil 0
0000
0001
0010
0011
as well as some more tabular data that isn't included.
So for example, I want 0000 to occur at 0ns, then 0001 at 15 ns, then 0010 at 16 ns, and 0011 at 20ns. It seems like there is no way to set a custom delay in the .vec file using vector file commands other than inserting a bunch of 0000's so I was wondering if it would be possible to do that through the actual .sp file that uses my digital vector file.
If it helps, this is how I used the vector file in my spice file:
r9 vout<4> 0 1e3
r8 v<4> vout<4> 1e3
r7 vout<3> 0 1e3
r6 v<3> vout<3> 1e3
r5 vout<2> 0 1e3
r4 v<2> vout<2> 1e3
r1 vout<1> 0 1e3
r0 v<1> vout<1> 1e3
.vec 'tabvec.vec'
.print v(*)
.probe v(*)
.options post
.tran 1n 200n
So for example, I want 0000 to occur at 0ns, then 0001 at 15 ns, then 0010 at 16 ns, and 0011 at 20ns. ...
In this PDF file:
https://www.bioee.ee.columbia.edu/courses/cad/html/vector_file.pdf
on page 39 it says the following about tabular data:
So I'd try not using the period directive and adding timestamps to your tabular data. That page of the PDF also contains this example:
; format: time vector
0 000101010
10 011010101
20 000101010
