Based on the same device and 2 AA size rechargeable batteries from this question - Rechargeable battery calculation
Now, the device is used to charge a small 5 inch tablet that have a 3600 mAH battery.
By theory, the device using 2 AA size rechargeable batteries will have a total of 2 x 1900 = 3800 mAH.
Compare to the tablet battery which is 3600 mAH, it should be able to fully charge the whole tablet.
However, when the device with the 2 AA size rechargeable insert and use to charge the tablet, it only manage to charge a max of 20% before the device start blinking and could not charge anymore.
So, the 2 AA size rechargeable batteries of 3800 mAH is only able to charge the tablet for a value of (20% x 3600 mAH = 720 mAH)
So, there is a huge difference of 3800 mAH (the 2 AA size rechargeable battery) minus 720 mAH (the amount it can charge the tablet) equal to 3080 mAH.
So, does it mean that the 2 AA size rechargeable battery of 3800 mAH have only 720 / 3800 = 0.19 (or 19% efficiency to charge a item)?
But the theory say that the 3800 mAH (2 AA size rechargeable batteries) should be able to handle the 3600 mAH tablet battery.
A side note - the 2 AA size rechargeable batteries took 1 hour to charge the the tablet and it only can charge up to 20% of the tablet battery (which is topping up 720 mAH to the tablet battery)
Is there a problem with the circuit or the theory is wrong?
There are at least two key factors reducing the effectiveness of the battery-driven charger:
  1. Tablets, mobile phones and other devices that charge via USB cables, typically contain an internal switching regulator as part of the inbuilt charging controller: My HTC Desire phone's battery indicates 4.07 Volts at full charge, and the charging pin shows 5.2 volts, higher than the incoming USB voltage, so there's a boost regulator in there somewhere. Assuming 85% efficiency in each boost regulator (inside the tablet, and in the charger), combined efficiency is 0.85 x 0.85 = 0.7225 or 72.25%. Actual efficiency is likely to be quite a bit lower.
  2. Unless the tablet is charged while fully powered down, it's own operation will be consuming a fair part of the total power delivered from the charger, thus both increasing charge time, and massively reducing actual charge delivery to the battery - most of the power ends up as operational and thermal losses in everything from the processor to the screen backlight, the radios for WiFi, Bluetooth, and perhaps mobile connectivity.
Observations on my various phones and other devices indicate that they go from a power-efficient mode to high performance mode (processor runs faster, screen brightens up) as soon as the charger is connected. While this could perhaps be prevented through power management changes in the device, the default behavior is power-hungry while charging.
For sizing a battery powered charger suitable for charging a mobile device, I would suggest a factor of at least 2, preferably more, in the mAh rating of charger compared to the target device.
Update: Power estimations, assuming [Eneloop HR-3UTGA][1] NiMH rechargable AA cells.
Tablet requires: 3600 mAh
Assumed efficiency: 85% (for each of the two boost converters)
Need from 2xAA: 3600 / (0.85 x 0.85) = 4983 mAh (to charge if tablet powered off)
Working the calculations the other way around:
Available, 2xAA: 3600 mAh (assuming around 1.5 Amperes drawn per battery)
    (Discharge graph in datasheet, between 1 and 2 A)
Delivered to tablet: 3600 x 0.85 x 0.85 = 2601 mAh (after tablet's boost converter)
Thus, clearly the 2xAA charger will not have sufficient power to fully charge the tablet, even when the tablet is powered off.
While it is not feasible to estimate power consumed by the tablet during operation, a totally "sounds like a good guess" assumption is in the vicinity of half to two-thirds of available power feed.
Thus the tablet should be expected to charge up to between 858 and 1300 mAh worth, before the AA cells in the charger are depleted. The observed figure is around that figure, so nothing significantly amiss in the behavior described in the question.
  • \$\begingroup\$ But it seems quite strange because I tested in the real life and notice that when switch off the tablet, it charge only 20%. If the tablet is on, it charge only 10%. 20% multiply by 3600 mAH is equal to 720 mAH (for 2 batteries which has a total of 2 x 1900 = 3800 mAH). Based on the testing, it seems that I need 5 sets of 2 AA size 1900 mAH rechargeable batteries in order to fully charge the tablet. (meaning that I need 10 x 1900 mAH = 19,000 mAH to charge a 3,600 mAH battery -> that is a huge inefficiency the battery or the circuit). Would be great if you can include these calculation as well \$\endgroup\$
    – Jack
    Feb 7, 2013 at 1:11
  • \$\begingroup\$ @Jack Nope, that kind of inefficiency means the device is just being unable to cope with the current draw of the tablet, it isn't working within its design parameters at all. There's no calculation for that. \$\endgroup\$ Feb 7, 2013 at 1:54
  • \$\begingroup\$ @Jack Nope How about doing math correctly and multiplying 3600 mAh with 3.8V to get 13,7 WH, multiplying 1900mAh with 1,2V to get 2,3Wh before applying any efficiency calculations. Law of conservation of Energy (measured in Wh or J) and not Charge put throught the cell(measured in Ah or mAh) does exist. \$\endgroup\$ Apr 4, 2020 at 11:12
