I will be powering a PCB using Li-Ion batteries. I will have 3 or 4 of them in series at max so 11.1V or 15V voltage will be achieved. Let's assume 15V.
I have LM2576 5V 3A regulator on the PCB (5V*3A=15W at max?) and the battery voltage will be directly regulated by this ic. 15W power will be supplied by 15 Volts so 15W/15V = 1A? I think I will be pulling 1A current at max from the batteries in total. I want to prepare for the worst, so I assumed 3A current will be the output current of the regulator.
I will be using something like the one in the picture below to connect the Li-Ion batteries to my board.
Q1: Is this safe to use? Should I use thicker cables? I see people using very thick cables for Li-Po batteries and I would like to know whether or not the same applies for Li-Ion batteries as well.
Q2: Am I doing the worst-case power budget calculation wrong? Should I be checking the LM2576 datasheet instead of multiplying the numbers on my own?
