If you want to be fast and be efficient to determine transfer functions, there is no other way than resorting to the fast analytical circuits techniques or FACTs that I describe in my book on the subject. However, and it could be the issue for an exam, I am not sure if the person who reviews your contribution will recognize it as a valid method as he/she perhaps expects the classical KVL/KCL approach.
The methods relies on determining the time constants when the stimulus - \$V_{in}\$ - is reduced to 0 V or replaced by a short circuit. You first start with \$s=0\$ and opens the caps (and short the inductors if any), just like what SPICE does during its bias point analysis. You determine the dc gain \$H_0\$ in this mode. Then, you temporarily remove each capacitor and "look" through its connecting terminals to determine by inspection (no equations) the resistance \$R\$ you see. Then, multiply the resistance by the involved capacitor to form the time constant \$\tau=RC\$. So determining the transfer function is mostly about splitting the circuit into small drawings that you individually solve and eventually fix if you spot a mistake in the end.
Once you have the natural time constants, you can form the denominator. For the zero, you have to identify a specific impedance in the circuit which could block the stimulus propagation if tuned at the zero frequency. As highlighted in the below picture, it is when the parallel combination of \$C_1\$ and \$R_1\$ would become infinite. And this is true for \$s=s_z=-\frac{1}{R_1C_1}\$.
This is it, we have everything to be happy and a Mathcad sheet can check these results. I usually build a high-entropy expression obtained with Thévenin in this case and make sure both answers are rigorously similar in magnitude and phase. This is the case here. As I said, should you spot a small deviation, then review the individual sketches and fix the guilty one without restarting from scratch as any other analysis would require:
Because the roots are real in this circuit (the quality factor is low), you can try to model the transfer function with two cascaded poles and a zero. As shown in the below plots, all three expressions deliver the exact same response:
If I count the time needed to determine the expression using FACTs, it does not exceed a few minutes. Should I now expand the Thévenin expression, first it's likely that I make mistakes while expanding the equations but, second, I will need more time to format the expression in a nice low-entropy format.
