I tried searching for this to no avail. I hope I'm not all too wrong asking it here.
I have set up my 60W CO2 Laser with a SKR 1.4 Turbo board and connected a 10k NTC thermistor to measure the temperature of the CO2 tube itself, taping the sensor on top of it.
The problem is that sometimes when the laser fires, the board resets itself - probably due to EMI. When I remove the connection to the NTC, it works fine, further proving this theory. Be noted that it only resets the board sometimes, not everytime. It's probably "just" above tolerance.
Looking near the TH connections, I see some basic filtering circuit, if I'm not mistaken.
(Image source: https://github.com/bigtreetech/BIGTREETECH-SKR-V1.3/blob/master/BTT%20SKR%20V1.4/Hardware/BTT%20SKR%20V1.4-SCH.pdf)
Shouldn't this protect against some degree of EMI?
Is there anything additional that I can do to (further) reduce noise in order to avoid the board reset?
