I was reading this application note from Microchip (AN1149) and I can't figure it out why this P-channel MOSFET (Q1) is placed like this:
I thought the parallel diode integrated with the MOSFET will allow battery voltage pass to the load, why it isn't?
I thought current through an p-channel MOSFET used as a switch goes from source to drain, but this appnote shows source is connected to the load an drain to the battery, why is that?
Regards!
