I've made a buffered RC phase shift oscillator. I have a problem with its frequency constantly rising.
It is not oscillating around a value but rising.
I've made a homemade PCB and I've used an LF347N.
I'm measuring the frequency with a multimeter on range of 2KHz. After two to three seconds, the frequency increases, which repeats.
What causes this? Is it temperature related?
Edit
What I am looking for:
  • No microcontroler
  • Cheap (less than 5$)
  • Sine waveform
  • Stable 1Khz +/- 10%
  • 5V RMS
Using a different circuit is fine by me.
Oscillator will be a part of a circuit which will be used to measure capacitance.
circuit
  • \$\begingroup\$ The comment chain length has exceeded what is reasonable for comments. Therefore it has been moved to chat and should be continued there (link below). --- As this bulk moving of comments to chat can only be done once, any further comments posted here which try to discuss / clarify / understand the question, might be deleted without notice. Keep it in chat, please! When someone has got enough information from the chat to post an answer, then please do that. Any factual updates to the question which are decided during the chat, should be made via an edit to the question. Thanks. \$\endgroup\$
    – SamGibson
    Commented Jul 2, 2021 at 17:09
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$
    – SamGibson
    Commented Jul 2, 2021 at 17:10
In the comments you say
power rails are +-12V...
when I blowed on the IC, frequency dropped and when I left it running for 10 minutes, turned it off and then on again after 10 seconds, it was showing the same frequency but when left for some time and turrned on again, it showed frequency around 1K3 Hz.
This is a sure sign that self-heating is causing at least some of the drift. The LM347 has a typical quiescent current drain of 8 mA. 24 V x 8 mA = 192 mW. Junction-to-ambient thermal resistance is ~43 °C/W for the DIP package and ~75 °C/W for the SOIC version, so there will be significant temperature rise inside the chip. This can cause various parameters of the IC such as input offset voltage, gain, phase shift and output saturation voltage to drift. Heat may also flow into other components in the circuit and make them drift too.
An oscillator that doesn't have level stabilization will increases its output level until the waveform becomes compressed. In this case the first op amp's output will hit the supply rails (less saturation voltage of 1.5 V per rail), producing a square wave that is low pass filtered by the subsequent stages. The last stage's output is close to a sine wave, but the amplitude is too low. You could lower the gain until the first stage only barely saturated, but then the level would become very sensitive to changes in temperature and supply voltage.
For your application it might be better to produce a square wave with a separate low drift oscillator (eg. LMC555 timer or CD4060 oscillator/divider), and use the LF347 as a 4 stage low pass filter to suppress the harmonics.
  • \$\begingroup\$ Yeah I figured. I was actually looking at using CD4060 with a crystal to get stable 1KHz and then either the same 3 RC stages or 2 integrators. I'll accept your answer and for anyone looking at using this oscillator, don't. \$\endgroup\$
    – Hedgehog
    Commented Jul 4, 2021 at 15:12
