i'm working on a little bridge PCB with USB C Male for one side and EVAFLEX 5 VS connector (http://www.i-pex.com/product/evaflex-5-vs) on the other side. The target of this is to replace the USB C cable by FFC connector. The USB C side is connected to USB C Female on RealSense D435i device (3D camera), and the other side will be connected by FFC to a PCIe to USB 3.0 outputs (RX, TX and D lines).
My question is, what happens with CC lines? On the original design that FFC is USB-C to USB-A cable.
EDIT: I have broken USB-C connector of USB-C to USB A connector and I have found this:
I understand the RP function but, which is the capacitor C1 job?
EDIT 2:
I have found USB-C specification, and there is an explanation about USB-C to USB-A (page 90) (https://www.usb.org/document-library/usb-type-cr-cable-and-connector-specification-revision-21). On the next tab, there is a note for A5, but nothing about B5 (VCONN), I understand I have to connect to RP too but it doesn't seem pretty obvious.
If I'm seeing it correctly, it's placed across VCC and GND. So it's a decoupling capacitor. Nothing special.
About Rp and Rd resistors on CC lines, take a look at this document.
  • \$\begingroup\$ I have added a tab about Rp and USB-C to USB-A specifications, but I don't know if I should to connect VCONN (B5) to the 5.1k resistor. \$\endgroup\$
    – Juanma
    Jul 5, 2021 at 13:31
