I get a model error in LTspice from adding a high-side driver, VN820PT-E for my library.
But after simulation, I have an error message. " Too few nodes: draw " .
I don't understand this error. Any advice?
Here is the schematic.
This is file.LIB
EESchema-LIBRARY Version 2.3
#encoding utf-8
#SamacSys ECAD Model VN820PT-E
#/14707361/538787/2.49/5/0/Integrated Circuit
* connections:      IN
*                   |   VCC
*                   |   |   OUT
*                   |   |   |   STATUS
*                   |   |   |   |   GND
.SUBCKT VN820PT-E   1   2   3   4   5
F0 "IC" 1050 300 50 H V L CNN
F1 "VN820PT-E" 1050 200 50 H V L CNN
F2 "SOT455P1410X1350-5N" 1050 100 50 H I L CNN
F3 "https://componentsearchengine.com/Datasheets/2/VN820PT-E.pdf" 1050 0 50 H I L CNN
F4 "Gate Drivers 9A 36V HIGH SIDE" 1050 -100 50 H I L CNN "Description"
F5 "13.5" 1050 -200 50 H I L CNN "Height"
F6 "STMicroelectronics" 1050 -300 50 H I L CNN "Manufacturer_Name"
F7 "VN820PT-E" 1050 -400 50 H I L CNN "Manufacturer_Part_Number"
F8 "" 1050 -500 50 H I L CNN "Mouser Part Number"
F9 "" 1050 -600 50 H I L CNN "Mouser Price/Stock"
F10 "" 1050 -700 50 H I L CNN "Arrow Part Number"
F11 "" 1050 -800 50 H I L CNN "Arrow Price/Stock"
DRAW
X IN 1 0 0 200 R 50 50 0 0 I
X VCC 2 0 -100 200 R 50 50 0 0 W
X OUT 3 0 -200 200 R 50 50 0 0 O
X STATUS 4 0 -300 200 R 50 50 0 0 P
X GND 5 1200 0 200 L 50 50 0 0 W
P 5 0 1 6 200 100 1000 100 1000 -400 200 -400 200 100 N
ENDDRAW
ENDDEF
#End Library
    \$\begingroup\$ Did you simply change the DEF line for a KiCad symbol library to .subckt and hoped that it would work in simulation? \$\endgroup\$
    – Ste Kulov
    Commented Jul 2, 2021 at 13:35
Two issues:
  • LTspice simulation must include the operation ".lib /path/to/file.LIB" for the .lib file to be loaded (this is not visible in the image.)
  • The "file.LIB" appears to be a KiCAD EESchema file type, not a SPICE 3f5 file type. While the format looks similar, SPICE is not going to understand this EESchema file; it is not a SPICE model.
You need a SPICE simulation model, sometimes called a "card" or "deck" file. The contents of this file should look something like the following:
*** SUBCIRCUIT DEFINITIONS
.SUBCKT NAND 1 2 3 4
* NODES: INPUT(2), OUTPUT, VCC
Q1 9 5 1 QMOD
D1CLAMP 0 1 DMOD
Q2 9 5 2 QMOD
D2CLAMP 0 2 DMOD
RB 4 5 4K
R1 4 6 1.6K
Q3 6 9 8 QMOD
R2 8 0 1K
RC 4 7 130
Q4 7 6 10 QMOD
DVBEDROP 10 3 DMOD
Q5 3 8 0 QMOD
.ENDS NAND
The above is taken from the SPICE Page at Berkeley.
Checking ST.com, they don't seem to offer a SPICE model for this item. Web search reveals nothing else. If you can find a SPICE model for this part, it might work, but finding one seems unlikely.
  • \$\begingroup\$ Hi, Thanks for yor return, So I simulated this model but i have a message error. He could not open the library file. This is tree weeks I works to create model but I haven"t result. I have test .lib<NAND it's dont simulate a message error. In the file what you propose I don't see a GND and the pin STATUS compare a component VN820PT-E STMicroelectronics ? This is my simulate . \$\endgroup\$
    – Amadou
    Commented Jul 2, 2021 at 14:48
    \$\begingroup\$ You need a SPICE model specifically made for the VN820PT component. ST doesn't seem to offer one. If the SPICE model file does not exist, then you cannot go any further. The NAND is just a SPICE example. \$\endgroup\$
    – rdtsc
    Commented Jul 2, 2021 at 15:38
