I can solve this circuit with nodal analysis, however, why is $$V_a=-V_b$$ in this ideal op-amp? Can I find this relationship from Kirchhoff's voltage law?
\$V_a = V_b\$ because the op-amp has ideally infinite open loop gain and of course, if \$V_a\$ didn't pretty much equal \$V_b\$ then the output would be slammed against the power rails. Negative feedback ensures that \$V_a\$ pretty much equals \$V_b\$.
I'm unsure why you think that \$V_a = -V_b\$ because that would be wrong. Maybe you have messed a sign up somewhere.
In order to compare voltages, they must share the same reference for One of the two +/- probe paths.
Yours does not. Its inverted. So Vin- = Vin+
Since ground by definition is defined by your choice of 0V, even if floating, that is the reference you should choose.
That statement Va=-Vb is just to make you think and understand this point.
But in reality, Vdiff = Vout / feedback gain (typ) 1e5 for BJT’s .
Why is Va=−Vb in this op-amp?
It isn't.
IF all input and output voltages are within the device's normal operating parameters AND IF there are no over-currents or current limiting AND IF the device is a theoretically perfect opamp
THEN Va = Vb, not -Vb
In a classic inverting amplifier topology, R1 and R2 form a simple voltage divider between V1 and Vo (Vin and Vout). Negative feedback drives the R1-R2 noce at the inverting input to be equal to the non-inverting input.
