I have some theoretical electronics knowledge from uni, but when it comes to applying it in practice, things can get a little bit complicated.
I've built simple stomp box, basically a piezo transducer glued underneath a top of a box. When you stomp on it, it is supposed to capture a sound. It was way too quiet when plugged in to my guitar am. As it is supposed to imitate kick drum, treble and some mid frequencies should be filtered out. I decided to assemble a simple active low pass filter to work as a preamplifier - amplify the signal a little bit and filter out high frequencies.
(source: https://www.electronics-tutorials.ws/filter/filter_5.html)
How do I build preamp like this around an LM386 without frying my guitar amp? I know that the LM386 has something more "on board" than a standard op-amp, so it might be a little bit harder than treating 2nd pin as op-amp minus, 3rd as plus and so on, leaving 1, 7 and 8 (gain and bypass) unconnected. Especially that somehow its default amplification seems to be set to 20. I've seen people building full-time amps around this chip, but I've been wondering whether pre-amps are also doable.
I want to use an LM386 specifically because I have handful of them lying around my house and I don't feel like waiting for a different op-amp.
