I have an old PCB with an edge connector and I am looking for a way to create a socket for it. I have a 3D printer so the housing is not an issue but where I am stuck is the contacts.
The edge connector has 25 fingers. Each finger is 3mm wide and 6mm long. The finger spacing is 5mm. The fingers are on both sides of the PCB.
Are suitable pin contacts available separately? I can't seem to find them.
Is there a suitable off-the-shelf edge connector socket where the pins can be removed without damage to them and they are the right size?
I believe on the original socket the pins were 1mm wide.
Thanks!
