This is my original file saved as "example.v"
module example(a,b,y);
  input b,y;
  output a;
  assign a=b&y;
endmodule
This is my testbench file saved as "example_tb.v"
module testbench;
    reg t_x, t_y;
    wire t_z;
    example DUT ( t_z, t_x, t_y );
    initial
        begin
            $dumpfile(“example.vcd”);
            $dumpvars(0, testbench);
            $monitor ($time, "t_x=%b, t_y=%b, t_z=%b",t_x, t_y, t_z);
            #5  t_x = 1’b0; t_y= 1’b0;
            #5  t_x = 1’b0; t_y= 1’b1;
            #5  t_x = 1’b1; t_y= 1’b0;
            #5  t_x = 1’b1; t_y= 1’b1;
            #5  $finish;
        end
endmodule
Command I runned:
iverilog -o mysim example.v example_tb.v
Error reported:
example_tb.v:7: syntax error
I give up.
Your apostrophe chars are the problem
should be
 $dumpfile("example.vcd");
And for all the literals, such as,
they should be
#5  t_x = 1'b0; t_y= 1'b0;
  • \$\begingroup\$ Perfect, Thank you! \$\endgroup\$ Jul 9 at 6:26
  • \$\begingroup\$ Typical copy-paste bug! \$\endgroup\$
    – Mitu Raj
    Jul 9 at 7:12
