I'm building a BLE peripheral device using the ST BlueNRG-MS chip and need to implement a few features where I'm not really sure what's the right way to go. This is my first BLE project so maybe someone with a bit more experience could shed some light on the issue.
1. Let "known" devices connect automatically
While pairing should only be allowed in a specific device mode, an already paired device should be able to automatically reconnect.
My idea was that I have is that the device has to be discoverable
all the time, and I store the address of the 10 last paired devices. So when a new device connects I check if its address is stored in this list and if not I refuse the connection. Or if in pairing mode, I add the new device to the list.
Question: At what point of the connection process can I do that? I assume I only get the EVT_LE_CONN_COMPLETE
event in the user_notify
callback. At what point is the connection to the central device established? If I don't call GAP_ConnectionComplete_CB()
if the address is not in the list, would that work? It seems that the central device then still can see all the available service, but is just not able to read them. But after that the BLE connection seems broken and the peripheral is not visible anymore.
2. Read the name of the Central Device
Beside the phone's address I'd also like to store a human readable device name. How can I do that? I assume I have to use some GATT command to read the device name, but how can I now what I have to read? Is the device name always 0x2A00?
3. Automatic update interval for characteristics
Is it possible to use the BlueNRG API to have a automatic characteric broadcasting? Currently I do this manually by calling the function
aci_gatt_update_char_value()
for the corresponding characteristic but that's kinda cumbersome. Does the stack provide an automatic approach for this problem?
