In digital logic, there's a state called "1" which is a defined high voltage, for example 2.7 V - 5.0 V. To achieve it we must connect it to VCC.
And "0" which is a low voltage, for example 0 V until 0.8 V. To achieve it we must connect it to GND.
And there's another state called "don't care", or "high impedance" or "invalid state" in which those wires are not connected neither to GND nor VCC. It's called floating wire.
The problem is, how do I check of the current state of the wire is floating?
It's easy to check the logic state of a wire using voltmeter. If it displays 2.7 - 5 volt, we can say 1. It depends on the logic level.
But what if the voltmeter displays 0 volt? There are two possibilities: that the wire's logic is 0, or it's a floating wire.
So what tool/method should I use to check if the wire is floating?
don't care
,high impedance
andinvalid state
are not all the same ... the only one that meansdisconnected
is thehigh impedance
