What you have drawn is a buck converter but, more specifically, it's called a synchronous buck converter. The 1N4148 diode brings nothing to the party.
These types of buck converter have extremely low losses in the energy transfer to the tuned circuit (a clue to why your output is oscillating).
Also, you have no load on the output hence the Q-factor of the LC circuit is infinite and, the capacitor voltage will continue to oscillate forever. This is what happens with tuned circuits without damping. You apply a step input (be it pure DC or PWM) and the output continues to cycle up and down for all time.
Add a reasonable output load and watch the output voltage stabilize to a constant value. For the values chosen (10 μH and 1 μF), with a 100 Ω load, the output sinewave will decay like this: -
Interactive RLC calculator link.
A mechanical analogy is turning on a motor that is driving a flywheel via an elastic rope. The flywheel starts turning slowly at first (as the rope starts to twist) but, eventually, as more twists in the rope occur (producing more transmitted force), the flywheel reaches the same speed as the motor.
However, because the elastic rope is still exerting a force on the flywheel (due to it being twisted up by the motor rotations), the flywheel continues to accelerate until it reaches twice the motor speed. At that point the elastic rope becomes full untwisted and no extra force is exerted.
But now, the motor speed is half the flywheel speed and, this situation begins twisting the rope in the opposite direction. This slows down the flywheel until eventually (and momentarily) it stops spinning. The elastic rope is fully untwisted again and, quite naturally, the process repeats forever. Of course, mechanical losses cause the flywheel speed to eventually become constant just like adding a resistive load to your circuit (as recommended).
- Output voltage = flywheel speed
- Input voltage = motor speed
- Flywheel = capacitance
- Elastic rope = inductance
- Twists in rope produce force and force is equivalent to current
It's irrelevant the the input is a 50% duty cycle squarewave - the output capacitor still reaches twice the average voltage of the input. If your PWM was 25% then the output average voltage would be 0.5 volts and the output capacitor peak voltage would be 1 volt and fall to 0 volts cyclically at the same oscillation frequency.
