This term is mentioned in the Micron Application Note: Hardware Tips for Point-to-Point System Design on page 10 (...For signals with lead-in termination...), however I've been struggling to find out exactly what lead-in termination means.
It's quite a difficult google search term: I finally found a reference to "Lead-in vs loaded routing" in this, one of the last pages.
Searching for "Lead in vs loaded routing" gives 3 results, one of which is the above, the other two are not particularly helpful.
Can anyone explain what lead-in termination is, or point to me to a book, or a synonym that's more widely used?
DDR memory so easy, a caveman could do - RTP Designers Council
that is involved varying your trace impedance based on whether you're routing a DMM module or the backplane: The slide mentioninglead-in
says:Neck down traces on DIMM modules to compensate for capacitive loads
— Increases impedance on traces
— 55 ohms on PCB and 60 ohms on module
