I'm suing TCAN33x from Texas Instruments and it's a 3.3v CAN-bus tranciever. I have succeed to listen for CAN-bus messages from a 24V J1939 CAN-bus stepper motor. Very industrial.
But I haven't succeed to send commands to it. I haven't tried to much to communicated with it. But I notice something in the data sheet of the TCAN33x https://www.ti.com/lit/ds/symlink/tcan334.pdf
CANH will be between 2.45V to 3.3V (Vcc = 3.3) and CANL will be bewteen 0.5V to 1.25V
But when I searching on CAN-bus signal, the CANL and CANH is much higher than so. For example here CANL is between 1.5V to 2.5V and CANH is between 2.5V to 3.5V
But still, the data sheet of TCAN33x says.
Question:
How can 3.3v CAN-bus transceiver communicate with 5 volt CAN-bus transceiver if they are not at the same level of voltage?
    \$\begingroup\$ The difference between CANH & CANL is much more important than their individual absolute values. \$\endgroup\$
    – brhans
    Jul 12, 2021 at 13:47
  • \$\begingroup\$ @brhans Ahhhh! Now I understand! It's the diff that counts! Thank you. So I can read OBD2 with TCAN33x? If you want, you can write an answer to this question and I will accept it. \$\endgroup\$
    – euraad
    Jul 12, 2021 at 13:52
“ The use of single 3.3-V supply enables the transceivers to directly interface with 3.3-V CAN controllers/MCUs. In addition, these devices are fully compatible with other 5-V CAN transceivers on the same bus”
Page 3 https://www.ti.com/lit/ds/symlink/tcan334.pdf?ts=1626098583867
This is due to the differential voltage method of reception of these signals on a controlled impedance within either common mode voltage.
This IC has a Vcm range of -12V to +12V on the receiver input.
  • \$\begingroup\$ Thank you for the answer. I assume the TCAN33x will work for all kind of CAN-bus e.g ODB2 etc. \$\endgroup\$
    – euraad
    Jul 13, 2021 at 0:22
  • \$\begingroup\$ It should at the physical layer. \$\endgroup\$ Jul 13, 2021 at 0:44
