I have an idea. USB singals are differential singals and they look the same as CAN-bus signals, even if they are USB signals.
Is it possible to use CANopen protocol to transfer USB signals to other devices? For example, if I connecting the USB differential cabels like this simple "hub". I borrow this picture. I know that this is not how a USB hub working, but it's just for illustrate the idea that CANopen can be used with USB signals? Or does it?
What is the most commonly protocol for transmitting messages in USB?
    \$\begingroup\$ USB is USB, CAN is CAN. You can place a "gateway" between, that will translate one to another. \$\endgroup\$
    – Eugene Sh.
    Jul 12 at 14:09
  • \$\begingroup\$ @EugeneSh. Thank you for your reply! I understand that USB is USB. Do you recommend som protocol for USB if I want to have communication between a PC and a microcontroller? \$\endgroup\$
    – MrYui
    Jul 12 at 14:15
no. That's wrong; end of story, really.
no.
That doesn't work with USB; a hub in USB must be an active device. You cannot connect two USB devices in parallel to the same data lines. You say you know this, and it's true, this doesn't work.
Completely different topic!
So, do what everyone does: Either get a microcontroller that does USB natively (high likelihood that your CAN-enabled microcontroller does), or get a USB-to-serial converter and use that with your microcontroller's UART.
Of course, you can also use a USB-to-CAN adapter and talk to your microcontroller's CAN interface, same idea really. But then your microcontroller "talks" CAN, not USB.
  • \$\begingroup\$ Thank you for your answer. What type of protocol should I use with USB? It must be some kind of way to have a proper communication? \$\endgroup\$
    – MrYui
    Jul 13 at 0:19
