Classic analog synths (like the modern Doepfer A100) tends to be somewhat power hungry, because they are based on discrete BJT circuits (we are talking about 1960-70 technology here). So +-12 or even +-15 supplies are the norm (also for noise issues: more signal voltage is less susceptible to noise!).
Using BTJs also means high biasing currents (also for noise, and most of the BJTs are working in class A), so, keeping the A100 example the standard power supply has 2A on the +12, 1.2A on the -12 and 4A on the 5V (no idea of why all this logic power is needed).
So a full fledged analog synth is quite difficult to run on the +5V 500mA nominal USB supply (about 2A if you use a USB charges). So unless you dig into USB-C power delivery (which is way more complicated that two wires in the connector) you have some serious power limitations.
The dual 12V supply is easy to obtain with a couple of power converters. If you only need a couple of oscillators and filters it will probably handle the load.
Or you could simply do a fake analog synth with a DSP like most people these day do anyway
