I'm working on a school project and my team needs the smallest GPS possible. With some help from stackoverflow, we found https://www.sparkfun.com/products/11571 from sparkfun.
This is good enough to prototype, but we were wondering if smaller GPS's exist out there just for knowledge's sake.
closed as off topic by Leon Heller, zebonaut, Nick Alexeev, Olin Lathrop, Dave Tweed Feb 10 '13 at 1:08
Questions on Electrical Engineering Stack Exchange are expected to relate to electronics design within the scope defined by the community. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about reopening questions here. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ "The smallest GPS possible for our project". What are the requirements? \$\endgroup\$ – user17592 Feb 9 '13 at 20:10
  • \$\begingroup\$ The requirements are that we can poll it for long/lat and hopefully it has decent battery life. Thanks! \$\endgroup\$ – cskoala Feb 9 '13 at 20:12
    \$\begingroup\$ You should add the requirements to your question. Decent battery life. What's the max current? What information do you need? How small should it be? Etc. etc. \$\endgroup\$ – user17592 Feb 9 '13 at 20:27
6
If you can use component level GPS, There are smaller modules from Trimble (Zelia), from OriginGPS (14xx and the 44xx). However, all such modules will require a PCB design. The smallest one is ~5x5mm, but does not include an antenna.
