I read some documents like the PoE application, it used ORing to protect the reverse input current. I would like to know what ORing is. I googled it, but I cannot find the answer. It seems like a diode or something the datasheet uses diode to protect, but I am not sure what this is.
1\$\begingroup\$ Can you provide a reference? \$\endgroup\$– FrogJul 14, 2021 at 9:47
\$\begingroup\$ In the power supply context, ORing uses a logic term to describe an analogue circuit function, described well by @TomCarpenter answer below. \$\endgroup\$– TonyMJul 14, 2021 at 9:52
20\$\begingroup\$ Or-ing, not O-Ring, in case that's how you were reading it. \$\endgroup\$– Andrew MortonJul 14, 2021 at 9:55
4\$\begingroup\$ @AndrewMorton I have seen O-Ring mentioned in a presentation in front of the entire engineering department. \$\endgroup\$– user253751Jul 14, 2021 at 10:39
1 Answer
OR is a logical function - the output is high when either input is high. ORing is simply a way of saying perform the logical OR of a set of signals.
In the context of power supplies, when ORing is used, the output (the device) is powered by whichever supply typically has the highest voltage.
A simple power OR gate can be made by diodes in series with each supply, which prevent power from the higher voltage supply backflowing into the lower voltage supply.
4\$\begingroup\$ EEC- No, there are other techniques besides diodes that can be used. FETs are used quite often as they offer lower ON resistance and so lower voltage drop than a diode. \$\endgroup\$– SteveShJul 14, 2021 at 11:17
3\$\begingroup\$ @EEC this might be a good read. Product specific, but it gives some insight. Keyword: "Ideal Diode" and "Load switch" \$\endgroup\$ Jul 14, 2021 at 11:29
3\$\begingroup\$ I parsed it a O-Ring and wondered what it was talking about. \$\endgroup\$– JoshuaJul 14, 2021 at 20:01
3\$\begingroup\$ @Joshua - I couldn't decide between
or-ing
,o-ring
and0-ring
. These all sound just like they could be a specific technical term. :D \$\endgroup\$– Vilx-Jul 15, 2021 at 6:58 -
