I'm using this encoder https://www.cuidevices.com/product/resource/acz09.pdf to scroll through a menu and I'm having an issue where when you turn it clockwise, it thinks the button was pressed (this does not happen when I turn it counter-clockwise). They're both on two different interrupt pins (2,3 on Arduino Pro Mini) and my code is included below as well as the schematic.
#include <SoftwareSerial.h>
#define Button1 2
#define pinA 3
#define pinB 4
//encoder setup
String bits[] = {"00","01","10","11"};
int bump[] = {0,0,-1,1};
byte state = 0;
int Level = 1;
byte M_pressed = 0;
byte T_pressed = 0;
unsigned long lastButtonPress = 0;
int page = 0;
int setting = 0;
String Motor;
int MotorState = 0;
String Heat;
int HeatState = 1;
byte change = 1;
byte Tempchange = 1;
unsigned long windowStartTime = millis();
float SetTemp;
int TempState =1;
double Setpoint, Input1, Output1, Input2, Output2;
SoftwareSerial OpenLCD(1,7); //RX,TX
byte contrast = 2;
void setup() {
Serial.begin(115200);
//encoder
pinMode(pinA,INPUT_PULLUP);
pinMode(pinB,INPUT_PULLUP);
digitalWrite(pinA,HIGH);
digitalWrite(pinB,HIGH);
pinMode(Button1,INPUT_PULLUP);
//interrupts
attachInterrupt(0,knobTurned,RISING);
attachInterrupt(1,buttonpressed,LOW);
OpenLCD.begin(9600);
//////Interrupts/////////////////////////////////////////////////////
void knobTurned(){
static unsigned long last_interrupt_time = 0;
unsigned long interrupt_time = millis();
// If interrupts come faster than 200ms, assume it's a bounce and ignore
if (interrupt_time - last_interrupt_time > 250)
state = 0;
state = state + digitalRead(pinA);
state <<= 1;
state = state + digitalRead(pinB);
//Serial.println(state);
if (setting == 0){ //if you are in general menu, scroll through temp/motor
Level = Level + bump[state];
if (Level > 2) Level = 2; //Level 2 is motor menu
else if (Level < 1) Level = 1; //Level 1 is temp menu
Serial.println(Level);
else if (setting == 2){ // if you are in motor menu, scroll through motor settings
MotorState = MotorState + bump[state];
if(MotorState > 4) MotorState=4;
else if (MotorState <0) MotorState=0;
Serial.println(MotorState);
else if (setting == 1){ // if you are in temp menu, scroll through temp (res 0.5)
SetTemp = SetTemp + bump[state]*.5;
if (SetTemp > 75) SetTemp = 75;
else if (SetTemp < 25) SetTemp = 25;
Setpoint = SetTemp;
Serial.println(SetTemp);
change = 1;
void buttonpressed(){
//Serial.println("pressed");
if (Level ==1){ //if button is pressed at temperature setting
if (setting == 0){ // enter into temperature menu if in general menu
setting =1; //Allow to scroll through temperature
Serial.println("enter Temp");
else if (setting ==1){ //if in temperature menu
Setpoint = SetTemp;
setting =0; //returns to main menu
Serial.println("Back T");
else if (Level ==2){ //if button is pressed at motor setting
if(setting ==2) { //if in motor menu
setting =0; //return to main menu
Serial.println("Back M");
else if(setting ==0){ //if in general menu enter into motor menu
setting =2; //Allow to scroll through motors
Serial.println("enter Motor");
delay(50);
last_interrupt_time = millis();
change = 1;
void loop() {
// put your main code here, to run repeatedly:
Menu();
void Menu(){
if (change == 1){
if (setting == 0){ // if in the general menu
if (Level == 1){ // if on temp arrow
OpenLCD.write('|');
OpenLCD.write('-');
OpenLCD.write(254); //Send command character
OpenLCD.write(128 + 20 + 0); //Change the position (128) of the cursor to 2nd row (64), position 0 (0)
OpenLCD.print("-> Set Temp: "); //For 16x2 LCD;
OpenLCD.print(SetTemp); //For 16x2 LCD
OpenLCD.print(" C");
OpenLCD.write(254);
OpenLCD.write(128 + 84 + 3);
OpenLCD.print("Set Motor");
else if (Level == 2){ //if on the motor arrow
OpenLCD.write('|');
OpenLCD.write('-');
OpenLCD.write(254);
OpenLCD.write(128 + 20 + 3);
OpenLCD.print("Set Temperature");
OpenLCD.write(254);
OpenLCD.write(128 + 84 + 0);
OpenLCD.print("-> Set Motor: ");
if (MotorState <= 0) Motor = "off";
else Motor = String(MotorState);
OpenLCD.print(Motor); //For 16x2 LCD
else if (setting == 1){ //Temperature menu
OpenLCD.write('|');
OpenLCD.write('-');
OpenLCD.write(254);
OpenLCD.write(128 + 20 + 6);
OpenLCD.write(254);
OpenLCD.print("<- Click to Return");
OpenLCD.write('|');
OpenLCD.write('-');
OpenLCD.write(254);
OpenLCD.write(128 + 20 + 9);
OpenLCD.write(254);
change = 0;
if(setting ==0){
OpenLCD.write(128 + 0 + 3); //Change the position (128) of the cursor to 2nd row (64), position 0 (0)
OpenLCD.print("Temp = "); //For 16x2 LCD
OpenLCD.print(SetTemp);//12x
OpenLCD.print(" C"); //For 16x2 LCD
