Question is the following:
lets say that all interfaces a modules are defined correctly:
module SOCKET (RD_IF rd_if, WR_IF wr_if, input ... /* list of common connections */);
   RD_IF rd_if_socket;
   WR_IF wr_if_socket;
   SOCKET_RD read_socket_module(rd_if_socket);
   SOCKET_wr write_socket_module(wr_if_socket);
   assign rd_if.A = rd_if_socket.A;
   ... // THis is painful way to make these connections
endmodule
SO the Question is how do the do the above connection of an instantiated interface inside a module to the interface defined in the module port list -- without doing it the tedious way of one connection at a time.
The reason I need to do this is because the SOCKET_RD/WR both share common signals that I would like to only connect once (instead of doing the connections twice to both modules in the TOP)
Currently Systemverilog does not allow assignment of one interface instance to another (ex. IF_A_1 = IF_A_2). So an instantiated interface cannot be connected to an interface defined in the module port list without doing the connection by hand, one variable/wire at a time.
An alternative is thinking of an interface as a single backplane that you make connections as a whole, and your sub-connections using a modport. The interface IS the connection, not something you make connections to.
module SOCKET (SOCKET_IF sif);
  SOCKET_RD read_socket_module(sif.RD_IF);
  SOCKET_WR write_socket_module(sif.WR_IF);
endmodule
interface SOCKET_IF;
  bit clk, reset;
  // RD signals here
  wire rwire;
  logic rlogic;
  // WR signals here
  wire wwire;
  logic wlogic;
  modport RD_IF(inout rwire, output rlogic, input clk, reset);
  modport WR_IF(inout wwire, output wlogic, input clk, reset);
endinterface
module SOCKET_RD(SOCKET_IF.RD_IF rd);
endmodule
module SOCKET_WR(SOCKET_IF.WR_IF wr);
endmodule
  • \$\begingroup\$ Hey Dave, nice to see you here, so this would fix the issue of connecting the common signals to the WR/RD sockets inside module SOCKET, but to connect rd_if/wr_if to the instantiated interfaces (rd_if_socket/wr_if_socket) is still the larger issue here as that takes quite some time \$\endgroup\$ Jul 19, 2021 at 18:19
  • \$\begingroup\$ yes, this is a great workaround \$\endgroup\$ Jul 20, 2021 at 15:43
  • \$\begingroup\$ I would say remove the first part, as it is not relevant to the question, and add a small snippet about the original question (can you assign instantiated interface to module port interface), basically saying that it is not possible, and here is a workaround..., then I would be happy to accept. I would be happy to edit it myself, it you don't mind... \$\endgroup\$ Jul 20, 2021 at 15:51
  • \$\begingroup\$ It's a great alternative, the modport option \$\endgroup\$ Jul 20, 2021 at 16:28
    \$\begingroup\$ verificationacademy.com/forums/systemverilog/… -- leaving this here for anyone who wants to see a longer discussion on this matter \$\endgroup\$ Jul 20, 2021 at 19:35
