Dear people of the internet, I seek your wisdom in figuring out a specific (analog) situation that puzzles me.
Recently I got my hands on a HF transceiver, the Kenwood TS-120V, which was not working. Upon investigation, it turned out to be a very common (so say the internet) problem with a PLL unlock, due to a missing carrier tone. This is the carrier schematic of the unit:
Kenwood TS-120V carrier oscillator unit schematic
As many have previously said regarding this issue, I immediately started suspecting Q1 to be the issue. After taking it out of circuit, my suspicions were proved correct by the help of those cheap component testers - the gain (hFE) of the removed Q1 (2SC460B) measured to be 26. This is way below the rated 60 to 120 values for hFE for the B group of transistors.
I read somewhere that a suitable replacement for the 2SC460 (which is long gone from production) is the 2SC945 (which is somewhat available in local shops, but still long gone from production). I immediately ordered couple of 2SC945P (P grade that have a hFE range of 200-400) from a local shop. The received 2SC945P's all had a current gain (tested with the same component tester, unfortunately only at one operating point) of a bit over 300. Putting one 2SC945P in the place of Q1, I was not able to get the oscillator up and running. Note: I have removed the carrier board out of the radio and made sure that all voltages on the connectors are the same as if the board was in the radio. In this specific case I was enabling the X1 - USB crystal. I tried re-tuning the T1 coil, but with no luck - the oscillator would not start. I started doubting that the larger gain of the 2SC945P would hamper the circuit from starting up.
Luckily I did order some extra 2SC945P's from another shop, which also had a similar hFE compared to the first batch of 2SC945P that I got. As luck would have it, using a 2SC945P from the second batch, with a hFE of 327 (I'll call these the good 2SC945P's), and re-tuning T1 I got the oscillator to start up and produce a signal on the CAR pins on the bigger connector (on the output of the Q3 buffer).
Immediately I noticed that I was not able to get the amplitude level required by the service manual (of 300mVrms) out of the carrier board, regardless how I tuned the T1 lug. The maximum amplitude that I was able to get was 125mVrms.
To investigate what might be causing this, I swapped the good 2SC945P from Q1 with Q2 (an original factory placed 2SC460B). The 2SC460B from Q2 measures a hFE of 76. A bit on the low side from it's group, but still within the B group. After the swap (Q1 = 2SC460B and Q2 = 2SC945P), and re-tuning of T1 to get the oscillator to work (I suspect that this is needed due to the different capacitance of the two different transistors), I got quite a larger amplitude of 265mVrms out of my carrier board.
This is puzzling me, as I can't answer what practical transistor parameter is causing this difference. On one side, when Q1 = 2SC945P and Q2 = 2SC460B I have a transistor with higher current gain in the oscillator section, but I have an overall smaller output amplitude from the board. On the other side, when I have Q1 and Q2 swapped, I have a transistor with a smaller current gain in the oscillator section (76 vs 327) and I have a much larger output amplitude of 265mVrms from my CAR board (albeit still not the required value of 300mVrms).
Puzzle 1: How/why does the new 2SC945P transistor, with a larger hFE gain impact the over-all oscillator amplitude?
I assume that the bias point of Q1 hasn't changed drastically on the new 2SC945P transistor, as this is an emitter follower, with a reactive load on it's collector.
Puzzle 2: If my assumption is wrong, or not fully accurate, what are the transistor's parameters that are affected by the quiescent current (dictated by R13, R14 and R15) that affect the oscillator - especially the amplitude?
Puzzle 3 (related to puzzle 2): What would you recommend that I do (change in the circuit) in order to get the desired output amplitude of 300mVrms of the carrier board, while using the a good 2SC945P for Q1 (and leaving Q2 to be the original, factory placed 2SC460B)?
Thanks for any feedback that you might provide me! Cheers
  • \$\begingroup\$ Link to the two data sheets please. \$\endgroup\$
    Jul 18, 2021 at 11:45
  • \$\begingroup\$ Your Hfe measurements are static, DC measurements. 2SC460 is a high-frequency transistor whose gain*bandwidth product is something like 1500 MHz, while 2SC945 is more like 100 MHz. \$\endgroup\$
    – glen_geek
    Jul 18, 2021 at 13:11
  • \$\begingroup\$ @Andyaka here are the links: renesas.com/us/en/document/dst/2sc460-2sc461-datasheet and rcscomponents.kiev.ua/datasheets/2sc945.pdf \$\endgroup\$
    – A_L
    Jul 18, 2021 at 15:09
  • \$\begingroup\$ @glen_geek according to the datasheets that I've linked, their fT (gain * BW) products is similar, 230MHz for the 2SC460 and 250MHz for the 2SC945. There are several datasheets that can be found online for both transistors, having slightly different values for fT, but I have never found a datasheet for the 2SC460 that mentions fT to be 1.5GHz \$\endgroup\$
    – A_L
    Jul 18, 2021 at 15:10
  • \$\begingroup\$ Your oscillator is biased near 1mA. 2SC460 (Hitachi) lists power gain at 1mA bias between 13-17 @ 100MHz. That's a VHF transistor. 2SC945 shows GBW of 100 at 1mA bias...at 100MHz it has power gain of 1. That's a general-purpose transistor much like 2N3904. \$\endgroup\$
    – glen_geek
    Jul 18, 2021 at 15:21
And there's your problem - they are not equivalent. The 2SC460 is a high frequency transistor designed for VHF applications. The 2SC945 is a general purpose transistor designed for audio and low speed switching use. Although the specs may look similar, in your application high frequency performance is critical.
In your circuit Q1 is operating at a Collector current of ~0.9 mA. At this current typical gain-bandwidth product of the 2SC460 is ~230 MHz, whereas the 2SC945 only achieves ~90 MHz. That means the 2SC945 will have lower gain and oscillation amplitude will likely be less (if it oscillates at all).
Your assumption is not wrong. With this biasing scheme HFE has very little impact on the bias point.
Try increasing Collector current by increasing the value of R14 and/or reducing R15. This should increase high frequency gain and oscillation amplitude. I would try increasing R14 to 15 kΩ, which should increase Collector current to ~2 mA and raise the cutoff frequency to ~150 MHz. If this is not enough then reduce R15 to 470 Ω.
Usually the 2SC460 fails after 30 years in the TR2300 synthesizer (Q16).
Replace with BF199 of BF 224. I had this issue in at least 3 radios.
