I need to replace a diode on heavily damaged board. Unfortunately, I don't have any schematics. It is an SOD-123 package (I measured it and it is around 3.6 mm width.)
Is there a way to identify it?
Sorry for the image quality, I hope is enough to identify the component.
  • \$\begingroup\$ I hope that damage was caused mechanically, otherwise the fault that lead to this is probably still there and replacing the diode might not be sufficient \$\endgroup\$ Commented Jul 18, 2021 at 17:10
  • \$\begingroup\$ Yes.. unfortunately the damage was a mechanical one…an human error on mounting the board on the main system \$\endgroup\$
    – Marco
    Commented Jul 18, 2021 at 17:20
    \$\begingroup\$ that's good! if it was electrical, you'd probably have a problem elsewhere, too. Anyway, context for identification is usually helpful: can you show what components are around this? Maybe even reverse-engineer the schematic a bit? \$\endgroup\$ Commented Jul 18, 2021 at 17:21
    \$\begingroup\$ Can you still measure it's forward voltage to determine if it's a schottky? Perhaps this is some manufacturer's marking for the popular SS14. \$\endgroup\$ Commented Jul 18, 2021 at 17:31
  • \$\begingroup\$ Why is your image mirrored? Surely you can take a better picture than this and, if you took it originally, how did you manage to mirror it? \$\endgroup\$
    Commented Jul 18, 2021 at 17:38
Possibly 40V 1A Schottky diode.
Photo from LCSC.com: enter image description here
