I am designing a PWM controller for a butterfly type flow valve operated by a servo. I have some information for the servo like input signal range (0-100mA), servo coil resistance (75 Ohm) and inductance (150mH). I am thinking of a simple architecture as per picture below. I have a few questions to address:
- At what frequency should I drive the servo. What are the means to determine best frequency at which you have better control?
- I set servo voltage source to 7.5V (75 Ohm * 100mA). I do realize that impedance of the coil will depend on frequency (PWM DC). What approach should I use to set the servo voltage. I assume it needs to be at a voltage such that control current doesn't exceed 100mA at 100% PWM duty cycle?
- How to pick an appropriate fly-back diode?
- How to decrease current ripple at the servo coil. Right now my simulation shows 20mA current ripple. Is this appropriate?
- Any other considerations or issues I need to think about?
