So this is my first time using altium designer and below is part of my schematic where the board receives 5 input signals from another device, which will determine whether or not the diodes light up. I1, the edge connector, I had to add to the library myself as there was not a component for this.
However, when on the PCB Editor, there is no connection line between Input Logic I1 and the 5 diodes like there is in the schematic. Additionally, I cannot connect the diodes to the input logic in the PCB.
How can I
- Make the connections correct or
- Get altium to ignore what connections can/can't be made and just let me connect I1 to the diodes
Thanks in advance,
