I have been working on the grid forming inverter control. I have started with the cascaded voltage and current control loop i.e. control structure like that
As far as I understand correctly this control structure its inherent feature is that the supplied current is limited by reducing the output voltage.
Let's say I would like to further limit the supplied current via reducing the output frequency (especially in case that one of the grid connected devices is the squirell cage induction motor). Current limiting via frequency reduction should occur independently to the current limiting via output voltage magnitude and I would like to have following sequencing where at first the current is limited via voltage magnitude and then via frequency reduction.
I have noticed that I have basically two action variables for current control
- output voltage magnitude
- output frequency
This fact drove me to the idea that I can use the well know split-range control and modify the above mentioned control structure in that way
As far as the splitter block its responsibility is to split the common action variable into the output voltage magnitude according to the following characteristic
and into the output frequency (indirectly via modification of the angle step) according to the following characteristic
I am not sure whether that idea could work. I have especially doubts regarding the modification of the output frequency via the angle step because in that case different transform angle is used for the actual values of the grid voltage calculation and different transform angle is used for the calculation of the reference voltage for the modulator.
