So I came across this interesting question while researching CMOS logic gates:
As is says, a logic function \$Y\$ is given and you are required to create a logic network that implements it. I am familiar with how to draw CMOS logic gates when given logic functions, but I am unsure how to interpret \$Y\$. From my understanding, say I wanted to draw the PUN first, I would need to solve for \$Y\$ in terms of complemented variables. Likewise, if I wanted to draw the PDN first, I would need \$\overline{Y}\$ in terms of uncomplemented variables (where the bar indicates a complement).
How would you interpret \$Y\$?
Can you assume that \$Y=\overline{ABC+D}\$? If this assumption is valid, then going through the logic gives \$Y=(\overline{A}+\overline{B}+\overline{C})\overline{D}\$, which I can draw a PUN for since \$Y\$ is now in terms of only complemented variables. The PDN could then be found via duality.
Another thought I had was to represent uncomplemented variables as double complemented variables (i.e. \$A=\overline{\overline{A}}\$ and so on) and solve from there.
    \$\begingroup\$ Since this looks like homework I will only give you hints. No, I don't think you can show, using Boolean algebra, that \$Y = \overline{ABC + D}\$. A "compliment" is something nice that someone says about you. The word you want to use is "complement". Beyond that, I don't think you have the correct procedure in mind. To find the PDN you want \$\overline{Y}\$ in terms of uncomplemented variables, because a high input to an NMOS transistor causes a low output. \$\endgroup\$ Jul 23, 2021 at 18:45
    \$\begingroup\$ Working it in my head, if you only have non-inverted inputs available I think you'll need one inverter... and one way would be to calculate !Y, and then follow it with an inverter to get Y. De Morgan's theorem is your friend here. \$\endgroup\$
    – W5VO
    Jul 23, 2021 at 19:02
  • \$\begingroup\$ Thank you for the responses! The more I work on the problem, the more I realize that inverters will be needed, since \$Y\$ can't be solved in terms of only complimented variables and \$\overline{Y}\$ can't be solved in terms of only uncomplimented variables. \$Y\$ and \$\overline{Y}\$ would have to be solved separately, since I now believe that duality cannot be applied. The PDN and PUN circuits would look fairly simple then, with inputs into the PMOSs and NMOSs being \$\overline{A}\$, \$\overline{B}\$, \$\overline{C}\$ and \$\overline{D}\$ as opposed to \$A\$, \$B\$, \$C\$ and \$D\$. \$\endgroup\$
    – JTaft121
    Jul 23, 2021 at 21:00
The initial assumption is inverted.
The use of all NOR functions in open drain inverters means shared pulling R’s might produce a simpler answer.
\$Y=ABC+D\$ as given
\$Y={(\overline{A}+\overline{B}+\overline{C})}+ \overline{\overline{D}}\$
Simple diodes shared are “wired OR” and shared open drains are “wired NORs”
Then you may choose the N or P types with complementary output bias for either state active low impedance 0 or 1 in this selection of PUN and PDN’s. Normally Nch with PUN’s were preferred for the output as Nch were slightly lower output impedance for the same chip size.
    \$\begingroup\$ Thank you for your response Tony. How exactly did you get the expression \$Y=(\overline{A}+\overline{B}+\overline{C})+\overline{\overline{D}}\$ ? If you double complement each variable, wouldn't you end up with \$Y=(\overline{\overline{A}}+\overline{\overline{B}}+\overline{\overline{C}})+\overline{\overline{D}}\$ ? \$\endgroup\$
    – JTaft121
    Jul 23, 2021 at 21:06
