I’m trying to build a light fixture which uses a 24V 30W LED strip that can be connected through mains power to a typical Lutron TRIAC wall dimmer. I can’t seem to find any type of driver product which can connect the strip to the dimmer, and which is small enough to fit inside the 3.5x3.5x3 inch space in the fixture. Surely a solution for this must exist? Am I thinking about this the right way?
My thought is that a constant current driver (I’ve seen some that have TRIAC dimming) with a specially designed led circuit would do the job better, but I’m trying to use off the shelf led strips because of their form factor. As I understand it, led strips must be fed by a constant voltage driver. Is there a simple solution to get TRIAC dimming?
