I purchased this 70 Watt Amplifier Kit and built it. Unfortunately, the kits do not come with any instructions. I have managed to find a variety of web sites where people built the amp and offered perspective. The kit seems to be shipped in varying configurations. In any case, I built it and it does not work properly. It basically amplifies, but the input SWR as seen by my Ham radio is high. I am using a 50 Ohm dummy load as output. I have decided to model the device in LTSPice to see what is going on and work on the source impedance problem.
Here is a link to a site describing the amp/more info
https://www.qsoshack.com/make-a-45-watt-linear-amplifier/
The pictures show the transformer labelled as having a 2T:0.5T turns ratio. When the amplifier is active, the input signal goes thru an inductor(the transformer) to ground. My radio sees a high SWR (at 3.9 MHZ). The resister labelled R6 (18 Ohms)/Vertically placed was not described on some web sites, but another said to include it. The resister is over the secondary side of the transformer.
When I wound this transformer, I only used one piece of wire, as per most of the web site descriptions. I believe what I have shown in the photos is a binocular transformer? If it is not, please correct me. I am not sure how it can be built with only 1 wire, but I did it. How is the secondary linked?
One side of the transformer is soldered to a single contact area. The other side is soldered to 2 contact areas. The resister is over these two contact areas.
I wish to model this transformer in LTSpice. In LTSpice I can set up 3 inductors and use a K statement to link them. I am wondering how to determine the proper inductances to use for my LTSPice model. I understand the turns ratio of 2:0.5 would govern the ratio of the inductances on the primary and secondary. Aside from the ratio, how do I determine the inductance to use for the primary side (in Henries)? I have an inductance meter (LCR). Could I unsolder the two yellow wires , shown in one of the photos , and measure the inductance? If I did this, would the reading be muddied because the transformer is soldered to the board and the secondary is connected (somehow)?
If I use the turns ratio to determine an inductance to use for the secondary side of the transformer, is that value to be divided by 2 and then used for each of the two transformers on that side. The secondary side looks like it is center tapped.
Please post some advice on this modelling problem. I think my first uncertainty is the inductance value to use for the primary side?
If anyone knows what might needed to reduce the SWR as seen by my radio, that would be helpful. One person mentioned a cap in series with the transformer input. At first, I'd like to see this modelled in LTSPice and then test things there.
Thanks
