I have a function generator that has an output voltage of 10Vpp. I need to use it to drive a voice-coil-actuator (VCA) that operates on 35V and 11.7A.
I was searching for a solution to amplify the signal from the function generator to reach the required operating volt. Any ideas how to achieve this task? Can I use a transformer instead of an amplifier?
