I'm little new to Vitis and vivado. I have used ISE tools mostly for spartan 6 and it is steep learning curve for new tools.
I used iMPACT before with ISE to program flash using JTAG. Now with Vivado and vitis things are become more confusing for me.
What is real difference if I program flash using vivado and vitis ? I dont really get it. I know vitis has BSP bitstream and Vivado is just a hardware bitstream. When I use vitis "program flash" option then I can program the flash successfully but, after power cycle FPGA doesn't load config from the flash sit idle. I'm using CMOD S7 XCS725 and 2020.2 version.
