I am programming effects for an LED cube. The cube and the independent functions are working correctly. The problem occurs when I call turnon_layer function in a loop. The loop counter is not incremented.
for(i=0; i<4; i++)
  Serial.println(i);
  turnon_layer(1000,i);
The Serial monitor shows that i has a constant value of 0 throughout.
When I call the functions with constants, then the output is as expected.
turnon_layer(1000,0);
turnon_layer(1000,1);
turnon_layer(1000,2);
turnon_layer(1000,3);
My turnon_layer function is :
void turnon_layer(long time, int layer)
  boolean state = HIGH;
  long wait, start = millis();
  for(i=0; i<4; i++)
      if(i!=layer) digitalWrite(levelPin[i], !LOW);
      else digitalWrite(levelPin[i], !HIGH);
  if(time/2<10)  wait = time/2;
  else  wait = 10;
  while(millis()-start<time)
    state = !state;
    //Serial.println(state);
    //First 8 LEDs
    for(i=0;i<2;i++)
    for(j=0;j<4;j++)
    digitalWrite(ledPin[i][j],state);
    //Next 8 LEDs
    for(i=2;i<4;i++)
    for(j=0;j<4;j++)
    digitalWrite(ledPin[i][j],!state);
    delay(wait);
I am using the Arduino IDE.
What is going wrong ? Why ?
  • \$\begingroup\$ Are you able to post the entire code including the setup() and void() methods as well as any variable declarations at the top? \$\endgroup\$ – Marko Feb 14 '13 at 4:25
  • \$\begingroup\$ @Marko: Did you mean setup() and loop()? \$\endgroup\$ – Dave Tweed Feb 14 '13 at 4:32
    \$\begingroup\$ @AnindoGhosh Now I definitely look mentally challenged laughing at my laptop. Thanks for that. \$\endgroup\$ – Marko Feb 14 '13 at 4:39
    \$\begingroup\$ @Swanand do you have anything concrete to back that statement? A quick scan at the Wikipedia For Loop Page reveals that just about every example uses i. \$\endgroup\$ – Marko Feb 14 '13 at 6:48
    \$\begingroup\$ But i means a lot to me ;) No pun intended. \$\endgroup\$ – Marko Feb 14 '13 at 6:51
Is the variable i declared as a global variable? i.e. at the top of the file outside all methods?
It may be getting overwritten by the loop inside your turnon_layer() method.
To test, just change the variable to letter k inside just one of your loops.
| improve this answer | |
    \$\begingroup\$ The experiment you're proposing will fail, because j is also used in the called function. In general, loop index variables should pretty much always be declared local to each function in which they're used. \$\endgroup\$ – Dave Tweed Feb 14 '13 at 4:33
  • \$\begingroup\$ Agreed, I have seen Arduino examples where i is declared with other variables at the top of the file. Generally bad practice. \$\endgroup\$ – Marko Feb 14 '13 at 4:36
  • \$\begingroup\$ @DaveTweed I saw your update and have updated it to letter k. \$\endgroup\$ – Marko Feb 14 '13 at 4:37
  • \$\begingroup\$ Yes, that was the issue. Making it a local solved the problem. \$\endgroup\$ – asheeshr Feb 14 '13 at 5:42
  • \$\begingroup\$ @DaveTweed I just had another look and I believe that unless j was declared at the top it wouldn't interfere because when specified in the loop declaration it becomes a local variable to that loop body. \$\endgroup\$ – Marko Feb 14 '13 at 20:33
