Does anyone know how to export board from EAGLE 9.6.2 to CADSTAR 2019.0, so that CADSTAR can be used for making a layout and further netlist?
Any readily available ULP script might help. The schematic need not be 100% exported correctly to CADSTAR, only a part of it gets copied correctly will be good enough.
  • \$\begingroup\$ I hope this help, but it does not work as it is outdated. eagle.support.eng.narkive.com/eT8YKh7H/… \$\endgroup\$ Aug 3, 2021 at 10:16
  • \$\begingroup\$ Its fine even if kicad-> CADSTAR solution is found out. Since EAGLE to kicad transfer is super easy. \$\endgroup\$ Aug 3, 2021 at 10:28
