A zero mean random signal is uniformly distributed between limits –a
and a
and its mean square value is equal to its variance. What is the r.m.s value of the signal?
\$\begingroup\$ The square root of this "mean square", by definition, since "RMS" is the square root of the mean square. \$\endgroup\$– Olin LathropFeb 14, 2013 at 14:33
\$\begingroup\$ how do we solve it. \$\endgroup\$– HOLYBIBLETHEFeb 14, 2013 at 14:35
This looks like homework, so here are some pointers :-
Firstly, you need to find the probability density function P(x) for the signal, given that :-
\$\int\limits_{-a}^{+a} P(x)\,\mathrm dx=1\$
The variance is given by :-
\$\int\limits_{-a}^{+a} x^2P(x)\,\mathrm dx\$
since the mean is zero.
The rms is the square-root of this by definition (as Olin says), so you have your answer in terms of a.
Q: A zero mean random signal is uniformly distributed between limits –a and a and its mean square value is equal to its variance. What is the r.m.s value of the signal?
A: $$V_{RMS}=\frac{a}{\sqrt3}$$
Proof: The RMS value of a signal is equal to the square root of the variance, only when the signal mean is zero. In this special case, RMS <=> Standard Deviation. Assuming this signal as a continuous random variable with uniform distribution between -a and a.
$$\sigma^2=\int_{-\infty}^\infty(x-\mu)^2f(x)dx$$
Doing the Mean µ = 0 and Probability Density Function f(x)= 1/2a:
$$\sigma^2=\int_{-a}^ax^2\frac{1}{2a}dx$$
$$\sigma^2=\frac{a^2}{3}$$ $$\sigma= V_{RMS} =\frac{a}{\sqrt3}$$
Remarkably is the same RMS value obtained for the triangular and sawtooth waveforms, both defined between voltages -a and a.
Or in peak-to-peak terms:
$$V_{RMS} = \frac{2a}{\sqrt{12}}$$
This result is useful when deriving the famous expression for the maximum ADC Signal-To-Noise-Ratio (for non Sigma-Delta types):
$$SNR (dB)=6.02n+1.76$$ where 2a = 1 LSB and n is the ADC number of bits.
