I'm trying to use a low-side MOSFET to disable/enable a few sensor module boards (MS5611 pressure sensor, MPU9250 IMU and a GPS/BDS module) connected to an ESP32 (which runs off 3.3V rails). These sensor module boards work with 3.3V supply, and probably consume between 50-150mA current (not measured, but a guess, and is probably on the higher side than actual consumption).
To perform a hardware reset and save power when not in use, I'm looking to turn off these modules using a low-side MOSFET AO3402 (primarily because this is available at local stores, and is cheap).
I'd like to understand if AO3402 is a good part number to use for the schematic below? An alternative part number available easily is Si2302DS. Is there a design that is better than the one here?
Thanks!
