I just wanted to ask a quick question. Mostly with the Arduino with buttons etc. you have to use a pull-up or pull-down resistor for the signal to be received correctly.
How does it look like when I want to send a analog control signal/voltage between 2 ICs (DAC and LED-Driver, "PT-4115").
Do I have to place a resistor in between those 2 for current limitation (schematic 2) or perhaps also one to ground (schematic 3) or both variants together (schematic 2 and 3)?
If so, does it have to be high/low resistance?
Here's a quick schematic attached:
edit: I cant use a PWM control signal, therefore needing to control the LED driver by analog voltage from a DAC.
