I wish to build a radio which can receive a 60kHz, amplitude modulated signal.
What is the simplest circuit that will achieve this?
Assuming a ferrite rod in an inductor/capacitor configuration, how would I tune this setup?
  • \$\begingroup\$ Tune, Amplify then Detect. (LC tune, OP amp, Digital detect.) Many OPAmps can do 60kc, without an IF stage. \$\endgroup\$ Commented Feb 15, 2013 at 3:59
  • \$\begingroup\$ Out of curiosity, what is transmitted on 60kHz carrier? This is such a low frequency. \$\endgroup\$ Commented Feb 15, 2013 at 4:03
  • \$\begingroup\$ 60KHz may be wwvb NIST \$\endgroup\$ Commented Feb 15, 2013 at 4:35
  • \$\begingroup\$ I'm listening for the msf time signal broadcast from England. (I'm in Ireland). Similar to the american wwvb signal. \$\endgroup\$
    – kobrien
    Commented Feb 15, 2013 at 9:40
Looks like you doing a time carrier for Europe. Ironically there was a discussion early about these types of antennas. Here is an example of a module for time code reception in case that is what you're looking for.
  • \$\begingroup\$ This is what I'm attempting to do but I'd prefer to built the whole thing myself. \$\endgroup\$
    – kobrien
    Commented Feb 15, 2013 at 9:42
I've just done this. As you want the MSF time code I expect you have a computer to read the result. I used the onboard soundcard and a few meters of wire into the microphone socket, nothing else https://drtonyr.github.io/MSF60decoder/
