Hmm... standard Modbus/ASCII does not use a frame break timeout of 3.5 characters worth. That timeout is characteristic of Modbus/RTU. Obviously if you own the implementation of all the nodes, this does not mean much. If your frame RX routine can detect end of frame based on frame contents (variable length frames have the length encoded early in the frame), you probably don't even need to honor the 3.5 characters worth in terms of RX/TX "turning time".
Once upon a time I've written a Modbus library for the PC, and I also happen to know a bit about the 16C550A and compatible UART's - but that knowledge is getting rusty. And I certainly know nothing about UART's occurring in MCU's. Being spoilt by the wasteful approach to pin counts in PC hardware, and having but a rusty fond memory of coding around the 16C550A UART hardware, I don't see what "using the UART in half-duplex mode" could save me in terms of code size or complexity.
That said - if I may suggest something to facilitate half-duplex RS485 operation, it would be using an UART that can steer the RX/TX automatically, by exporting the internal flag called "Transmitter Shift Register Empty" as an external discrete signal, which can be plugged directly into the RS485 level shifter (transceiver).
Note: do not confuse the desired "Transmitter Shift Register Empty" with the "Transmitter Holding Register Empty" = a different status flag in the UART. The former means the byte being currently shifted bitwise onto the line. The latter refers to the FIFO - and the THRE flag becomes active as soon as the FIFO is empty, i.e. while the shift register is still busy shifting out the last byte, i.e. too early for the RS485 transceiver to get disengaged into high Z / listening state.
Some UART implementations can send this signal as an alternative function of the RTS or DTR pins, others have dedicated output pins or can map this to some GPIO. The standard 16C550A only has the TSRE aka TEMT as an internal status flag, but lacks the capability to export this on any output pin. I.e. the 16C550A is not a stellar choice for RS485. As a shiny example of this function done right, I'd like to mention the late OX16C950 UART by Oxford Semiconductor, nowadays no longer manufactured (technical progress has its underside, and there was a string of acquisitions, roughly OX Semi -> PLX -> Avago -> Broadcom). If memory serves, modern UART's by EXAR can do it too, and some LPC SuperIO chips can also support this on some or all UART channels (Fintek, SMSC, maybe some recent ITE and Nuvoton nee Winbond). I don't have a clue about UART's in the various MCU's.
I seem to recall some UART's where this function is flawed - namely I recall an addon PCI board for the PC, with RS485 ports and HW steering, where the UART would switch the transceiver to high-Z (RX) one bit too early, effectively cutting off the stop bit. Which apparently worked fine against other UART's... I don't remember the brand of the UART chip on that board.
I've also seen a board-level design bug (thinko) in some asian industrial PC, where RS485 mode was implemented by driving the transceiver's RX/TX steering pin by the UART's TTL Data TX - so that the transceiver was switching between log.1 and high Z...
This feature, i.e. "TSRE=TEMT for RS485 RX/TX steering" can save you some headache with precise timing in software. It sure is a headache on the PC, especially under some modern OS... whether timing is a headache or not on your particular MCU, that's obviously your own business, YMMV.
