I've a circuit powered by a 3.3 V regulator. The regulator is a SMD one, with this logo and code on its surface:
Drawing of top marking and logo
footprint is SOT23-3 or very similar.
I need to know the valid range of incoming voltage. Unfortunately, I do not find any information about the V1TF marking code nor recognize the logo.
Any hint about how to continue?
The pinout is:
where Vout is 3.3v.
  • \$\begingroup\$ Clues come from the parts attached to it, the package type, taking measurements , estimating power load and the reason why you need this. \$\endgroup\$ Aug 10, 2021 at 16:24
  • \$\begingroup\$ pasaba por aqui - Hi, I changed this to an on-topic identification question, since asking for datasheets is often not well-received by the community - similar questions have been voted closed. You need to identify the device anyway, so start with that, as identifying the device will make finding the datasheet easier. However if you strongly disagree with that approach, you can rollback my edit. Thanks. \$\endgroup\$
    – SamGibson
    Aug 10, 2021 at 16:30
  • \$\begingroup\$ @TonyStewartEE75: SOT23-3 or similar; no idea about max power it supports; need datasheet to know valid incoming voltage to use it with different power supply than current one. \$\endgroup\$ Aug 10, 2021 at 16:33
    \$\begingroup\$ Can you provide a photo, measure the size and trace out the schematic around the component? \$\endgroup\$
    – winny
    Aug 10, 2021 at 16:47
  • \$\begingroup\$ @pasabaporaqui - Sorry, I wasn't clear. I mean that someone has to identify the device (I know that you have not been able to do it), before anyone can find its datasheet. That is why the step "identify device" comes before "find datasheet". As I said, if you disagree with my suggestion of making this a clear identification question, you can rollback my edit. (I have seen that logo on a voltage regulator. I can't think of the manufacturer at the moment, but hopefully someone else will identify it.) \$\endgroup\$
    – SamGibson
    Aug 10, 2021 at 16:52
A manufacturer with a matching logo is Nanjing Micro One. (Here's a link showing their logo on LCSC.)
Updated:
Further investigation shows that your device with top marking V1TF is the Nanjing Micro One ME6209A33M3G 3.3 V LDO, which has a maximum input voltage listed in its datasheet (both maximum operational and absolute maximum) of 18 V. The top code is V1xx where the xx varies (e.g. batch number / manufacturing date or similar) and V1 is the device identifier.
Explanation:
After the OP managed to find a photo from an AliExpress seller claiming to show the Nanjing Micro One ME6209A33M3G LDO with top code V1RC (though no manufacturer's logo), I found others claiming to sell the same device with the correct logo and these top codes:
device with top code V1RC
device with top code V1SE
device with top code V1Q1
and this seller even says in Chinese, that the top code starts with V1
Chinese text stating that device top code starts with V1
    \$\begingroup\$ Thanks a lot, very useful. Tomorrow I will continue this research line. \$\endgroup\$ Aug 10, 2021 at 20:05
    \$\begingroup\$ @pasabaporaqui - Well done, I think you found it! That one shows V1RC and the seller says it's the ME6209A33M3G. I then searched for that Nanjing Micro One part number, and see other photos with top code starting V1 e.g. zoom in here and see it is marked V1QH. So it seems very likely that this LDO is marked V1xx where xx will encode batch number / manufacturing date - this is a very common approach. I searched for V1 and LDO, but didn't find those photos. \$\endgroup\$
    – SamGibson
    Aug 11, 2021 at 11:08
    \$\begingroup\$ @pasabaporaqui - Here are more photos confirming that the ME6209A33M3G is marked V1xx where the xx varies: V1RC here; V1RK here; V1SE here - and this one even says, in Chinese, that the top code starts with V1. So I am convinced your device is the ME6209A33M3G. I'll update my answer. \$\endgroup\$
    – SamGibson
    Aug 11, 2021 at 11:30
    \$\begingroup\$ Thanks a lot, Good news for my target, I have some PIR sensors (3.3v) powered by this IC and distributed across a square of 40x40m. I want to power all them from a single DC 12v line. Taken into account copper resistance, consumption and distance to main power supply, I expect each device will receive from 12v to 7v. That agrees with this IC specs. \$\endgroup\$ Aug 12, 2021 at 12:20
    \$\begingroup\$ Thanks for the warning, I will keep it in mind. \$\endgroup\$ Aug 12, 2021 at 15:38
I suggest many of these choices for an LDO 3.3V will be suitable for replacement.
https://www.mouser.com/Semiconductors/Power-Management-ICs/Voltage-Regulators-Voltage-Controllers/LDO-Voltage-Regulators/_/N-5cgac?P=1z0wa2eZ1z0z5la
  • \$\begingroup\$ Thanks for your answer. At this moment I do not know if current regulator matchs my needs (this is the reason I need to identify it). If not, I will replace it as you say. \$\endgroup\$ Aug 10, 2021 at 17:06
The closest I can appear to come is the RAA214401 from Renesas. The logo appears similar to what you've drawn as well but as winny has requested in the comments it would be more helpful if you could post an actual photo of the IC in question and if you happen to know what pins perform what function (i.e. GND, V+, Vin) which is something you should be able to easily accomplish with a DMM even if you don't have a schematic of what you're looking at.
  • \$\begingroup\$ Thanks for your answer. Pinout has been added to the question. \$\endgroup\$ Aug 10, 2021 at 17:53
