So, I'm trying the age-old tactic of roasting coffee with a popcorn popper, and while it works, I would like to have better control over the heat applied in order to prolong the roasting. I've seen other mods to popcorn poppers, but the schematics for this one are bugging me.
I've got a bifinett 1200w popcorn popper, and to the best of my ability, this schematic represents how the internals are wired (I'm not an electrical engineer so I might be wrong). Note: I'm missing a capacitor connecting the two AC wires.
This is an image of the "Fancy Bridge Rectifier", which connects to a motor working as a fan:
And this is a picture of the heating element, with the labeled HL, HT, and HR points:
I would like to accomplish two things, both related to controlling the heat while leaving the fan always runnning:
Add a switch to, at least, the main coil, so that I can control the heat. This would be my main objective. However, from the schematic, I don't see how I can turn off the main coil without turning off also the fan and secondary coil. Plus, it seems to me that the main coil lowers the voltage that is passed on to the rectifier and secondary coil, so I don't see how to go around it.
Later I would like to control the main heating element with a solid-state relay so that I can control the temperature through an ESP8266 I have that is measuring temperature with a thermocouple positioned inside the heating chamber. This one I have no clue how to wire up, but this is also more for "future work", right now I want to accomplish 1) first.
