I just want to make sure that I wired up the power circuit for this F280021 correctly according to the datasheet.
1 Answer
VDDIO should be on DGND. It is on page 28 of the datasheet. I just place 0.1uF ceramic caps close to each and every power pins if possible, along with the large power bank (bulk) caps.
Edit,
Extra tip: Arrangement of AGND & DGND is critical.
Aggregate the "domains" of power (GND, VCC, VDD, VSS). Have those meet at a right place, while "looking" at how the current pass around. Yes, I do steer the current, and you can do as well.
